why we drop saving scrolls?
when i spoke to guidemax she told me it is random some times you dont drop some times you drop continusly.
please explain about saving scroll
many high lvl players say if u die u drop saving scroll
or if ur mercy dies u drop saving scroll
but i have on my own experience telling you this
when i was pked without mercy on i did not drop saving scroll atleast 4 times,
then when i died because of creeps 6 times i dropped saving scroll
all these 6 times mercy was on.
out of these 6 times which i am mentioning 4 times it was continuous in span of two days i died because of creeps and 4 continuous deaths i drop 4 saving scrolls.
saving scroll is a scroll which drops in place of an item about to be dropped by a player upon his death
is the above statement true or false??
if it is true then what is the probability or chance of a player dropping an item upon death
is player item drop rate equal to that of a grace or that of a priority hair[/color
many players carry around 500 mils + stuff on them i am being modest a full g10 carries stuff woorth 4000 mils now they cant afford to enter memora field also without saving scroll
if player drops an item evey time he dies
many players give shouts give back my item which i dropped at so and so loacation in so an so map and generally these items are of good value .
i dont understand why they dont carry saving scrolls
when i ask them they say i die too many times to carry saving scroll every time i die i have to buy one
but as per this statement it indicates players who are not carrying saving scroll and dieng many times drop item may be once in a blue moon because if item drops every time then no one will go out and saving scrolls will cost a lot more
so when item drops once in a blue mooon why saving scroll drops every time
is there a difference between death by pk or death by creep
if i die and get rced does my chance of dropping saving scroll reduce.
regards
sudhir
simply answer this
Instead of dropping an item when a player is killed, a saving scroll will be dropped first if there is one in the inventory. The saving scroll will lose its function if the player is in murderer(red) status.
Drop rate of saving scroll will be high if the players self defense are low.
When a player die by any cause the saving scroll will be dropped.
[GM]Diablo
