buzzyboy wrote:
so "ARTHY" cau u plz tell how can i killl.......
w8ing for ur answers....
Killing Ranias single handed is stupidity but I hear that the XP loss in the Ranias room has been removed on the Indian Server. But generally you can get this done.
You need a party of 7.
1. HK (Swordie)
2. HK (Swordie)
3. Mage (Ele)
4. Mage (Non Ele)
5. Archer (Bow)
6. Warrior (Spear)
7. HK Swordie.
I'll tell you the use of them all.
1. You will need the three sword HK's for RC'ing. Without RC - this mission would be totally impossible.
2. You'll need 2 mages to deal in insane damage.
3. An archer for ranged attack and deviations. Bow because the range is Max.
4. Warrior Spear - coz he can take down the Duskamiu thnx to the range of the spear and also he can act as an HP Tanker.
You can carry a lot of HP and MP candies if you wish.
Go to the Room, Mages Sed, SB beside the Actual Ranias and not any of its decoys. In the mean while- so as to not waste time - Archer and the warrior deviate the Duskamiu's to get away from the mages who are after the Ranias. Two of the HK's concentrate on the Mages (one each.) It's obvious that over a course of time they will end up getting stunned and then killed so instantly RC them. Do not get yourself killed no matter what. This is where skill comes in handy.
By the time enough damage is dealt on the Ranias for it to deploy the decoys, the Duskamius in the room would be dead if the warrior is efficient. Now it's time for the archer to deviate the decoys away from the mages so that mages can have a clear shot at the actual Ranias. The warrior should now just as a tanker and keep an eye on the HK's.
The third HK comes into play now. The job of the third HK is to do the same job as the rest two but instead concentrate on the archer who is getting the decoys away.
If this METHOD is executed to perfection - Ranias will be dead in 15 minutes. Else - 6-10 hours to kill all the decoys and etc.
That is a good method.
LAME METHOD: Take a bunch of archers and just UW it. Stupidity but.
