 Hope it mite help u ppl ..
Guide to do spl qst 2-1 and 2-2 ..
2-1
Summary on the qst:-
1. 2-1 supposed to be the hardest of all the spl qst as it not only requires skills but also brains ..
2. U need to Solve 2 puzzles in this spl qst .. This spl qst opens the way to grnita heath ..
3. The Puzzles arent so easy . One is a jigsaw puzzle knwn as Rabellus omate design. And the other one is a peg Puzzle .
IN which u need to remove the pegs and only 1 peg shuld remain in the last ..
4. All these patterns of puzzle and peg keeps chngin each time u do the qst .. They are not the same ..
Preparin:-
1. U need a party of 4 ppl to do the qst ..
2. The qst Begins in vemerdan deep inside the Vermedan Temple .. Or u can say frm where u can go to hatrel there the Goddess Rubells cms as Npc .
Doin the qst:-
1. After talkin to the Npc ur warped in to a Room Where u See Rubell 12 years before as a little girl .. Talk to the Npc or Little Girl.
2. Nw u need to find 2 things Moms Ring and Fathers dagger .. U got like sm 5 mins and there are 4 corners in the room full or Berkers. Dnt worry these Berkerrs arent hard and dsnt do much dmg u can kill thm with Even Fury of Thor ..
3. After Findin the 2 things run back to the Npc and submit it .
4. NW u need to search the secret door .. There Is a secret door located on one of the walls of the four corners and i think its always at one place .. The only thing is u need to knw the place..
5. Whn u find the secret door u need to solve the Rabellus puzzle u got 5 min to do so .. Hopefully if u hv succeded thn gud else gv a next try .
6. Nw if u hv done u can go on further u see a mini movie and thn u are given another peg puzzle i think its named sm Fireplace not sure.
7. U hv 1 min to do this .. The hardest 2 do i believe . This is as far as we hv done it .
8. Nw after this not sure as though i hvnt done it after here .. There is smthin called as path way of death filled with cynik and u need to run past em and i think u cant use skills there ..
9. And ur qst is done .
10. Though i aint sure what cms after peg puzzle so if anyone who does knws can provide me info so tht i can complete ma spl qsts guide ..
Rewards:-
1.U hv opened the way to grnita heath ..
Below are a few screenies of me and ma frnds doin the spl qsts.. This shall provide u sm info and the Help too ..
Screenies:-
1.Killing Berkers to obtain the Fathers Dagger and Mothers Ring ..
2.This is where the Secret Door is Located..
3. The pic of Rabella omate design
4. Another pic of the same design
2-2
Summary on spl qst 2-2 :-
1.2-2 is a splqst in which u need to kill the phoneix ..
2. It drops redyan necklace . (Not sure , do and chck it out)
Preparin:-
1.U need a party of 4 ppl ..
2. Best is a mage who has a very gud wip duration and the rest of the 3 can be anyone .
3.But to do fast kills better be a party of 4 mages
Doin the qst:-
1.The temple top or smthin tht place is called the co-ordinates are 105 96 (exactly where the spl qst npc 2-2 spwans)
2.Whn u activate the qst ur warped or teleported into a room and u see the timer tickin u hv like 10 secs .
Just run straigth and talk to the fountain of spirits ..
It does says smthin and after tht the party memeber take there positions in each corner of the maps.
3. There u can see Deneris spwanin .Well in this qst they do hv very low attck and hp bar so u can kill em easily . Keep killin thm till u obtain 10 keys . U get 10 keys .. Hand over all the keys to the qst holder .. THe keys are hvin numbers on thm and also arithmetic operations tht is addition , multipication and subtraction.
4. The keys hv numbers on it .. Use the Key combi to make the number 33. The combination will be 9+8-6*3 = 33 or 4*8+7-6=33 ..
5. Whn ur done with this ur again warped into a room were u can see it filled with denerrian .. These creeps cannot be killed by any skills .. Remember tht these creeps cannot be killed ...
6. The only way to kill thm is lure thm or bring thm into the centre of the map and wipnos thm .. Thn the qst holder goes to the other end of the map and uses a switch this switch crushes all the denerians standin in the middle.
7. But be carefull whn ur usin the switch no player shuld be inside else he to gets crushed .
8. Better to do two turns to kill the denerrians .
9. Whn ur done with killin all the denerians u see a mini movie and are warped into a room with phoenix.
10.Phoenix dsnt hv much attck but it does has a high hp bar .. So it mite take sm time to kill it and remember all these spl qsts are hvin timers..
Reward:-
1. U get Redyan Necklace..(not sure abut this)
2. U get a huge amount of exp .
3. I think even colorence gets unlocked(Not sure abut this also)
Screenies:-
1.The Temple of Deneroo as soon as ur warped/teleported whn u talk to Npc .
2.Taking postions after talking to fountain of spirits as it has a spwan time of 30 secs ..
3.Killing Deneris to obtain the keys..
4.After obtainin the keys and killin deneris .. Room of denerrians where u hv to wip em in the middle .
5.Killin the Phoenix ..
CREDITS:-
Well for the above guide the credits goes to Ben Alderson a.k.a Kovia (Leader of Kh Elysium in Hades).
Its becuz of him i came to knw hw to do the spl qsts 2-1 and 2-2 .. I am just writing the Guide and passin on the info i had
So tht u ppl can find it easy to do the spl qsts ..
REGARDS
TIMEKEEPER
 How did you do it?
 How did you do it?
