One of the slack leveling times, without leaching is around 35 to 50 for hks archers and warriors... mages ofcoourse have firefield and other area attks so no problem..
For the other 3 classes here are a few tips for you to hunt dugusu's, olgocs and harpy's...
Olgocs
once u enter carode (from quanato) go right near the rocky outcrop.. stand just beside the rocks and hit an olgoc when it starts attacking you.. that way only 2 others will spawn instead of four... whenever u get basic or elemental larcs use it.. dont keep it for later use.. u get plenty while playing..
Dugusus
Enter the dugusu pit and go to the central area (again speakin from quanato side), where there are all those greenish heads sticking out of the ground... the head on the left side, as soon as you enter the centre part from quanato side, is an ideal place for hunting dugusus... stand between the head and the wall of the pit... that way only one dugusu can hit u at a time... u'll find them queuing up one behind another to get killed...
Harpies
When u enter carode, move a little outside, u will find two paths on the ground, one going left n another right(upwards)... follow the right path n u will find lots of harpies... they will surround u n lagging cud be dangerous..
so either stand on the edge of the cliff(only 4-5 will surround) or stand against the rocks over there( only 3 can surround)..., that way u'll take very little damage..
Thats all for now.. hope low lvled players find it useful... the more u quest the more lore u get, n the better it is..
Thanks..
IGN: Katie
IGC: Archer 10x
