HERE R THE TRICKS OF BEING A SUCCESFUL PKER...
1. WARRIORS RELY ON THERE HP N ATTACK...KNOW UR OPPONENT
MAGES
1.MAGES R NOT HAVING MUCH HP N WARRIORS HAVE A LARGE HP BAR SO WARRIOR CAN WIN...BUT MAGE POWERS LIKE SB CAN KILL U EASILY IF U R ON AN LAGG OF EVEN 2 SECS..
2. DEAL N KILL MAGES--EASIEST IF AN MAGE IS NOT KNOWING THAT WARRIOR,HKS,ARCHER CAN MELLE ATTACK BEHIND THE TRADE WINDOW...
3. POWER OF SPEAR IS LIGHT,AXE IS FIRE,SWORD IS ICE...MAKE SURE UVE GOT HIGH OF THESE ON UR WEOPON.{DEFINETE INCRESED ATTACK}
4.SOME 1 IS DEALING U ??? U CANT ESCAPE?? PRESS F1 N F3 TO FUNCTION AS 1 N 3{1 N 3 DONT WORK IN DEAL WHILE F1 N F3 DOES}
5.IF MAGES HP ABSORBER IS REMOVED DEFINITE ATTACK INCREASE{ HK CAN PUT WARAT [NOT RANGED]OR HOLYWEOPON[RANGED]
AGAINST ARCHERS
1. OMG! SHES RUNNING LIKE HELL I CANT KILL HER SHITT!!.......NO DONT LOSE HOPE KEEP CHASING..TRY TO USE THE ENVIRONMENT AGAINST ARCHERS ARCHER MAY ATT N RUN BUT U CAN DEFINETELY ALSO.
2. XBOW ARCHERS HAVE A LOW DEFENCE SO U CAN TAKE THEM DOWN WITH A SURPRISE
3.DEAL THE ARCHER SEVERAL TIMES IF SHES RUNNING
AGAINST HK
1.HKS R VERY GOOD ONCE THEY RISE TO HIGH LVL...BOR IS AN AWESOME POWER MAKE SURE UVE GOT TIGHT CRIT RATE ON UR BOOTS TO BEAT BOR!
2.TRY TO CALL SM FRND N GET BOR N KARNA REMOVED FROM THE HK
3.HK HAVE A HP LOWER THAN WARRIOR SO AT LOW LVL (>95) U CAN TAKE THEM DOWN EASILY
COMMON TRICKS
1 INCREASING ELEMENTAL ATT RESPECTIVELY HELPS A LOT .
2 LARCS R UR BEST FRND WHEN NO 1 IS HELPING U CAN TAKE DOWN UR MAJOR ENEMY BY SURPRISE USING LARCS N THEN TP BEFORE SM 1 HITS..
3 REMEMBER F1 ALWAYS
4 NICEST TRICK IVE LEARNED IS...IF AN HK HAS RAZED U N U R STUCK POORLY..BEFORE UR HP FINSHES RECONNECT!100% GUARANNTEE ULL BE FREE FORM RAZ N WONT DIE ALSO..TP FAST WHEN U RETURN
5 WANT INCREASE MORE OF ATT? ALWAYS GO FOR A MOUNTED WEOPON THAN MOUNTED OTHER STUFF..
6 MAKE SURE UVE GOT BASICS+ELEMENTALS ON UR SHUE..(I MISS DEFENCE
HAPPY PKING
TigERfIgHTer
