well.......i had posted this topic in the general section too......but didnt recieved much replies!!!....so m posting it here again!!!
Is making a new character for leveling up a shue is better !!!!
or wasting away 1 r 2 passive point and some cash for early bird is a beter way!!
i've already bought weapon type pasive skill which is curently at level 3
so..........is resetting my passive after making an ss is a better way than making a new charcter and leveling it!!!
please helpme out........!!!
princeoni at level 112 with shue at lvl 77 and my noob char is at level 50 with a shue at level 40
i also wanna know the amount of exp a shue gets depending on the char's lvl
and a proper difference between a shue and char level!!!
Please reply.....( AND YEA........AGAIN.......I NEED ANSWERS .......NOO STUPPIIIDDDD POSTS PLEASE
~Princeoni
						Shue and its leveling
First, answer one question.... you made second char for your second shue. Will you be making a third char to level up your super shue?
If you are 113 now, by the time your SS has reached atleast midlevel, you will be 140+. Resetting of PS requires 100 million wz (I am not sure about the amount but it's a very high amount) plus you would have already bough some PS using your 35+ PS points which would have cost you 250 to 300 million. So would you like to waste 100 million + 300 million after you make your SS?
I dunno if Early bird is faster or lvling up shue with new char is faster. But resetting PS is not something I would ever go for.
Also, your shue will get max XP when the level difference between you and your shue is not very high. Ideally the difference should be less than 5 levels. You will get max shue XP from monsters who are 3 to 5 levels higher than you. Check boro's site for creep's level.
				Cursedblader
Yup exactly.
1.Make new noob id to lev 10x with just enough psp to get lev 3 early bird.
2.Get that id into super negative. If u lev up ur toon, then as we know ur shue dont get best exp. And best shue exp maps are either S1 or R4.
3.keep grinding till eternity.
4.Sell that id for some nice in game items.
				Cursedblader
				Suckkminee
OMG!!! R u ppl out of ur mind... Creating a new char and lvling up ur shue
Neways this is how I made my SS... At lvl 112 Haterel opened.. I had a lvl 81 shue and lvl 75 shue which I lvled up all by myself which is possible to ne player who is lvl 110...
I went and bought lvl 2 Early bird staright away... And I was questing in C3 daily... For every creep u kill u get around 5 xp to the shue... Along with it U get atleast 2 Neri G's per day(that is if u play for some 5-6 hours)... By the time I got to lvl 120 my shue was lvl 93+...
I started lvling up my lvl 75 shue in tao where u get 5 xp per creep... Here ur shue can lvl up super fast coz of the huge mobs and faster killing rate... And I used the occcassional G's which I got to the lvl 93 shue... By the time I got to lvl 125 I had a lvl 93 shue and a lvl 98 shue... I took some 11 G's from Truroe and made 1 shue lvl 100 and the lvled up the other shue to lvl 100 and made my SS...
Then I used a lvl 20 char to lvl up my shue till lvl 30 and I started using it... At lvl 130 each Tao creep gives u 4 xp to the shue per creep(with lvl 2 early bird)... That way, every 10% I get my shue used to get 1 lvl up... Now my shue is lvl 63+...
So here is my suggestion to U
1. Buy lvl 2 of early bird only... Buying lvl 3 early bird makes no sense... Lvl 3 costs u 50mil which is useless considering that it gives u just 1 xp more to the shue... More than nething else 1 precious psp is lost... U need to be wise in using ur psps.. Later regretting will not do ne good to u...
2. Make sure of ur SS combo... Don't keep changing ur plans... Just keep 2 shues and make sure U make ur SS only with ur SS combo...
3. Don't reset ur PSP... It consumes 100k lore and 30mil which u have invested on early bird 2 will go for waste... U'll need the early bird for lvling up ur SS... If u wanna think abt long term then it will help u make money as well.. If u can manage to get a lvl 100 SS.. Then u can start lvling up a lower lvl shue, get it to lvl 70+ and sell it for 50mil+...
