My char got deleted!!!! :( :x
i was hunting and then i got a message saying that my connection was terminated press ok to exit the game. I thought ok, maybe the gms are doing something. After a few hrs I came back, and was able to log back in but all my chars was gone!!! I really hope this is temporary cause there's no way I'm gona start again...it was fun while it lasted but i guess that'll be it for me.
Hey Akabee,
Dude, try loging in again. Also make sure that you use the same character case as you used while creating those chars. This means, if you logged in initially as akabee, make sure that u use the same case and not AKABEE or Akabee or AkaBee or any other combination. There is a login bug, which lets u login with different case of ur id, but then ur chars will not be there. Login with ur original id and the chars will be there.
Cheers,
StillWaters 'Eowyn'
Cheers,
StillWaters 'Eowyn'
