A3 port
"Hey what do i do?"
Rafiki
A3 port
Post by Rafiki »
what port does a3 run on ..
every time i try to start a3 (i am behind a biiiiggggg firewall - not under my juristriction!) its seems to be using a different port of my comp???
am i right? / is there some constant port it uses??
raf
Rafiki
Post by Rafiki »
i basically need to know
how to play a3 behind a firewall??
if any of u have any idea .. plzzz puts fundaes!
raf
Isildur
Post by Isildur »
Which firwall do u use? The windows firewall isnt much use. Try usin Zone Alrm or som other. Usually when u run the game, or ne internet program for that matter, the firewall asks u if u want to give it access to the internet.
If thats not the matter, then the security settings must be on very high or sumthn.
Don no much, but thats how i access the game thro firewall.
Rafiki
Post by Rafiki »
ok i am sorry i should have mentioned proxy ..
i am actually behind a proxy .. (and a firewall! in that proxy) ..
basically my proxy allows only http/ftp/ssh ports to come thro ..
so i need so know if a3 uses some constant ports or has some config file for me to change
so that i can make it use a constant port???
using this i can port-forward its! ???
any helpers on this??
raf
i
Chief
Post by Chief »
I would suggest send query to GMs or customer support.
Hawkwood
Some hint plz ?
Post by Hawkwood »
Chif yar , im using proxy i can acces the http all the sites but i
am not bale to play A3 y ?
for that what ip and what port number i reqire...?
if any one software to run A3 on proxy so plz give i also want's to lvl up
my 32 lvl caracter
tx
Eos
Post by Eos »
According to this thread on the sg server- http://forum.igamesasia.com.sg/showthread.php?t=5555
you need to open these two ports on your firewall-3550 and 3330.
