hi all,
I have all combos and required runes for doing crafting, have a few
doubts in crafting ..
(when i say crafting, i m actuall refering to adding opts)
* Will opts be set to max (for that class, grade) after crafting or will vary?
* When should i start crafting my stuff ? at wat lvl? and someone tell me
when to start crafting items, and adding opts for warrior?
* And when u craft g8 and above stuff is success rate 100%?
Im 5X archer and still using g3 set .., didnt want to waste wz, coz anyway
hunting just cynicz and peltons
thanx
IGN: Snipearcher
Crafting doubts
WHEN YOU ADD OPTS TO A ITEM , THEN IT WILL VARY RANDOMLY BETWEEN 1 TO MAX LIMIT, NEVER COMES BACK TO 0.
DON'T CRAFT RIGHT NOW, YOU ARE A ARCHER, YOU HAVE DECENT DEFENCE AND NEED FOR MOUNT ISN'T THERE, CRAFTING IDEALLY STARTS AROUND 90-100 WHEN PEOPLE START GETTING STUFF FOR THEIR G8/G9 AND START BOSSING!
CRAFTING G8 IS POSSIBLE BY RUNES FROM G7, AND ALSO G7 CAN BE CRAFTED FROM G6, THE CRAFTING SUCESS FOR UPGRADING AN ITEM BY GRADE TO G6 FROM G1 IS 100% BUT TO UPGRADE AN ITEM TO G7 AND THEN TO G8 IS A BIT RISKY DUE TO FAILURE POSSIBILITY!
CRAFTING G9/G10 HAS A 100% SUCESS RATE,BUT THERE WILL BE NO OPTIONS JUST PLAIN ARMOUR AT LEVEL 1.
DON'T WORRY CYNICKS AND PELTONS DROP AMAZING STUFF WHICH YOU CAN SELL FOR INSANE AMOUNTS OF MONEY!
Karaboudjan
ACHTUNG!
Dred made a mistake. Upgrading from G1 to G6 can fail! Only plus point is that even if it does fail the item wont be destroyed. On the other hand, the runes will be gone forever
and they cost a lot more than the item at those grades.
So dont go trying to get a g5 set by crafting ur g4 or you'll be broke before you can say oops
No I can simplify it even further. Just simple math. Rune 6 and above cost= 1 million. Does your item to craft cost atleast thrice as much in the market? If not, crafting is not worth it.the.prophet wrote:ACHTUNG!
Dred made a mistake. Upgrading from G1 to G6 can fail! Only plus point is that even if it does fail the item wont be destroyed. On the other hand, the runes will be gone forever![]()
So u end up with crafting ONLY at G7 and later.
Helpingheart
For hunting in c3 u defnetly need 2 boxes , 1 for hair and
other for scales i have box full of hairs (62) and 40 scales
just by hunting peltons and cynics
I got a few good ones like a few root of shaibd , Ner (G)
and lots of Ner(M) and L , having them in storg box , and
i dont even know hwmuch the above ones are worth
nothing useful other than this
Last edited by Helpingheart on Fri Jun 23, 2006 11:35 am, edited 2 times in total.
Suckkminee
rexdude wrote:Bah they never dropped anything for me...except an Iarrtek.dredisback wrote:
A Iarrtek
What else wud u expect... Greedy EOS...
I have only got 3 Neri (G), a few g7 stuff and loads of pointy hairs and scales...
