YOU HAVENT MENTIONED WETHER YOU ARE ELE OR NON ELE!!
WELL IF YOU ARE ELE I SUGGEST STAYING PUT IN R3 TILL 90 WHEN YOU WEAR YOUR COMPLETE G7 SET, EVEN IF MOUNTED I SUGGEST YOU STAY THERE TO AVOID LOSING MONEY, BUT IF YOU ARE NON ELE THEN YOU CAN IMMEDIATELY GO FOR R4 BLOOD AND HEART QUEST AT 86, USE THE HIT AND RUN TACTIC AS YOU WONT STAND MORE THAN 2 ES YAHGONS POUNDING YOUR HEAD!
IF YOU STICK TO R3, YOU CAN MAKE A MILLION A DAY FROM PURE DROPS AND THE QUEST OF LIROX NAMED "YIRUK YIRUK" FROM YIRUK OF COURSE GIVES YOU 65K AND 70K EXP WHILE YOU HAVE TO COLLECT 2 HORNS FOR EACH QUEST AND KILL 30 AND 31 LIROXS FOR EACH PART!
YOU CAN COMPLETE THIS QUEST UNDER 1 TRIP IF YOU HIT AND RUN, AND 2 TRIPS IF YOU STAND AND HIT, BUT YOU WONT' LOSE MONEY EITHER WAY AS THE DROP RATES AS WELL AS THE QUEST COMPENSATION IS REALLY GOOD!
FOR THIS QUEST I RECOMMEND YOU MAKE WAY TO R3 VIA TEMOZ, BECAUSE THERE ARE LESS ESKHUNS THAT WAY, THEN GO STRAIGHT, AFTER THE FIRST BLOCK TAKE A RIGHT TURN AND HUNT THERE, THAT PLACE HAS MAXIMUM LIROX POPULATION SO YOU CAN DO YOUR QUESTS REAL FAST.
I SUGGEST YOU CARRY A STORAGE BOX FOR KARDION ORES, LARGE AND MEDIUM NERIS, POINTY HAIRS!! THESE DROP MOST OVER THERE.
IF YOU GO FOR R4, THEN YOU HAVE TO KEEP RUNNING AND HITTING AS OTHERWISE YOU ARE LIKELY TO END YOUR TRIP UNDER 3 MINUTES WITHOUT A PARTY, AND THE TWO MOST HUNTED REGIONS ARE THE TOP RIGHT HANDSIDE CORNER AND THE OTHER IS IN THE CENTRE WHERE THE BOSS FOR R4 SPAWNS. YOU WILL ALWAYS FIND A PARTY THERE NO MATTER WHAT TIME OF THE DAY IT IS.
BETTER TAKE A HK WITH YOU FOR NECTEN IF YOU ARE UNABLE TO HANDLE IT FIRST, AND TRY TO GET A FREEZE WARRIOR IN PARTY WHICH WOULD BE BETTER. BUT BE WARNED YOU WILL LOSE MONEY A LOT IF YOU PARTY, FIGHTS OVER WHO GETS THE DROP ARE ALSO COMMON, SO BETTER MAKE A FEW RULES BEFORE JOINING A PARTY TO AVOID CONFLICTS!
INFO COURTESY:- SOLARIN[THE STUPID GHOST OF R3]
