hey guys i am havin a prob here
WTF does failed to connect to the login server mean. after i type my id and password this stupid thing comes in the side. pls help me.
GM's pls tell me how to get over this problem
IGN:Artimis, Felix , Slasherx
IGC:Bow Archer, Mage , Spear Warr.(respectively)
P.S pls help me
P.S.S GM's pls ans
						Failed to connect to the login server??
u should have posted this in registration issues
anyway it means either the server is down or smthing might be wrong with your conection
if server is down then try connecting after sometime
also u can try restating your computer
lots of ppl are online so probably server is down
btw change your id
also clear your intentions-do u want to abuse me or kept that id by coincidence
btw change your id
				Ankeetsinha
Everytime you enter your username and password, it has to be authenticated through the authentication server also called as the login server
Since the server is down as they are working on the new Nivea Canon map (not sure abt the spelling), you are not able to connect
Btw if it is happening with you, it is happening with everyone else
So dont sweat, kick out that frustration and relax
~Wardeath
~Wardeath
				Cursedblader
				Bloodraven
