God knows how it works...!! But if u notice evertime the image keeps changing... Ther is math calculations involved in this for sure!!
http://www.mysticalball.com/
Off topic.. But guys need to check this out!!
notice the symbols corresponding to 0, 9, 18, 27......(i.e. multiples of 9)
11 (11-2=9);
12 (12-3=9);
13 (13-4=9);
17 (17-8=9);
34 (34-7=27);
55 (55-10=45);
etc. etc.
so basically whichever number u choose will result in a symbol corresponding to a multiple of 9
-Typhlosion
(sheesh im a genius)
11 (11-2=9);
12 (12-3=9);
13 (13-4=9);
17 (17-8=9);
34 (34-7=27);
55 (55-10=45);
etc. etc.
-Typhlosion
In simple terms the way it works is
(10x + y) – (x + y) = 9x
Means whichever two digit number you choose, take the digit at 10’s place and multiply by 9 to get the value. All 9’s multiples (on the page) have the same symbol next to them, and they change to another similar symbol every time you reload the page.
No magic just Mathemagics
its not even that complicated, if u can notice, the difference between the sum of the two digits and that number will only give a certain amount of values. so the numbers from 11-99 will give only 22 different values i think no matter which numbers u choose, the results will just repeat after then 22nd so by having the same symbol of each of those numbers will get have u believe it's right all the time but actually it's just covering all its bases
