gm need help in this quest. check this out
Linkiran
Post by Linkiran »
hello sir, where I will get this quest item and also in which map
2014year 1month 22date 12hour 34minute 56second.jpg (405.77 KiB) Viewed 2320 times
Re: gm need help in this quest. check this out
You need to search for it in all of Clororence maps. Get accustomed to the map environments.
Lovelyrose
Post by Lovelyrose »
It is found in Ertarkin Map on Top Left (Its not a Spoiler the NPC through quest Dialog mentions that you need to go to Ertarkin Map to get the item).
A little Info on Quest
Quest Name : A Strange Aura
Condition : 161-165
NPC : Marishi ( Clororence Teleport )
Type : Chain Quest ( Mostly 12-13 )
Exp Rewards and items :
1 ) 180k + ( When only Hunting is involved )
2) 190k + ( When Hunting and Quest item is involved )
3) 1m + Saving Scroll ( Last quest in the chain )
Creep kills : Usually one type from 20-30 numbers
Its very hard quest and time consuming for Non-Mage Chars.
Quest Plot :
You are called as Bravo ( Should have been BraveHeart ) and you visit every NPC to hunt in every Clororence Map to get rid of Evil that lurks in the maps.
