Lvling up Shue Fast after player lvl 100
Thepowermage
Post by Thepowermage »
Hi,
I am a 100 lvl mage :o and want to know ways to lvl up shue fast :?: and make a super shue
have heard about a ring or sumthing after lvl 100 available that helps to gain 1 exp for shue for every kill made by mage for same lvl monster :shock: .
please help as my takes a lot of time for shue to go 1 lvl up. :(
my current shues are of 50 lvl and other 75 lvl.
please help me as which monster should i hunt or some product which i should buy. can shell out good woonz for it.
You can level up your shue faster by learning passive skill. The name of the passive skill is - Early Bird. You can buy the skill from NPC Rameda at Hatrel map X - 186 Y 184.
Required passive point to learn level 1 of the skill is "1 pasive points".
Maximum level of the passive skill is "6".
You will be getting 1 Passive point per level (Only After Level 100) E.G Your level is 101 - Your passive point will be 1.
This skill aslo got a negative affect i.e It will reduce your Woonz earned while killing monsters.
