@what lore do we get 20% realtion after 10% realtion?
Kerrwarrior
- Class: Warrior
i stayed in c3 parties till 70 lvl then after Jq i started hunting in r3 i could notice 10% realtion when my lore was 100k & 4m then to now i'm doing yarmo Quests only now my lore is 300k, can any one tell me how much lore do we need to have 10% to 20% & 20% to 30% realtionship with plz some one clear this
- Memoramaster
- Memoramaster
You're all wrong!
No two quests give the same amount of favour. Every quest is unique that way.
If you repeat a quest (better known as spamming a quest), you will stand to gain less favour than the quest normally contains.
So your math about (x * 100/200/300) is bogus. That does not work.
On re-submission (spamming), Quest favour is reduced by 20% every submission.
There is a better way though.
Alternate between quests. If your NPC provides only one quest at your current level, then alternate between quests from different NPC's.
You'll get gifts from the NPC's on quest submission ONLY once favour reaches a critical level. 35% is Critical. The A3 source code does not give an understanding of what happens if quest % goes beyond 35%.
Every time you quit a quest, you lose Favour. If you're doing a chain-quest, and you quit from the middle somewhere, then you lose a partial % of your accumilated favour.
Quiting a quest looses 2% of total favour gained till date.
Quitting in the middle of a chain loses anywhere from 0.1% to 1.9% favour, depending on where in the chain you decide to quit.
Just log into ragezone forums and ownload a copy of the A3 server/client. Then try to figure out how the server works. The config files can teach you a LOT of good stuff.
Have fun.. And any doubts or clarifications, catch me in game.
IGN: Samangel
KHL: Guywise
"Cause Guywise Has You!"
KHL: Guywise
