What is this ???
Hjkkhjkhj
What is this ???
Post by Hjkkhjkhj »
Recently i had to change my harddisk :shock:
But the problem is on the old HD a3 was running fine, and i had downloaded the client frm the website ; but after the change of HD i had to download again and this time smthing happened. While playing and changing a map in game i.e after the loading time sometimes everything becomes *white* all chars are full white only their outline is visible and also the whole ground is white and using of skills shows the same thing. :? :(
This mostly happens when i go from Egonihl to Hatrel and vice versa but also such as frm Q to T. Any 1 tell me y ? and smtimes after map load game completely freezes. :cry:
And most importantly after i end the program it says **Corrupted File : Reinstall Client** which i hv done abt 10 times still it persists. I think is there sm bug or technical fault in the download file itself frm the website ?? Then its a prob cuz a3 cd is nt available ( without online purchase) :roll:
Sm1 help and tell me is ne1 else having same prob ? :? :cry:
This could be because of some problem with your virtual memory. It is advisable to check with your system configuration.
Saadmage
Post by Saadmage »
Same thing happened to me... but my case was almost reverse of what u experienced. my old hdd started giving me problems. Then once i got a new one, with a fresh windows installation, it was workin fine.
You can try resintalling the OS once. if it doesnt work, try installing OS onto a different drive than where u do normally.
Hope it helps... :)
Memoramaster
Post by Memoramaster »
it happened wid me 2
it got cured but i donno exactly hw
i bought up a nw graphics card nvidia geforce 8600 and increased ma virtual memory to 5 gbs (coz i had lots of free space[:P])
check the virtual memory fact and if the prob presists try the other 1
hope it helps..... good _uck[:p]
The Phoenix is back
Have no fear Phoenix is here
