hi frend i am creating a g8 brakuel set bcos no body selling so i wanted to know a few thing b4 adding options....
1:: wats the max additional def
2:: when increasing lvl of kit does it increse.
3:: wats the use of full bless over kit
4:: wats the chances of it failing if i have a char with 30% npc relationship with kadru
wat is the max add def on a g8 kit
Re: wat is the max add def on a g8 kit
I think the add def is +5 at lvl 8... maybe more but not sure![]()
Yes... It will increase when you increase the lvl of the kit...![]()
If your stuffs are blessed... the success rate of enchanting of the kit will increase...![]()
That you can know by yourself... Usually it will have a good succes rate at 30% relation with npc... if you are receiving gifts from the kadru... then success rate will be amazing...
