Hi all
Just an update,
Feel happy these days hehehe.
Made some money selling a few degrades and a storeage box will help me buy my hp and mp potions
Indian chick has been amazingly helpfull a very big thank you, she gave me a shu and i think it helps, she is a very sweet person.
have done lots and lots of quests may have to repeat a few before i go to Carode as it seems tough there.
Just a few simple questions.....
Players ask if me if i be an axe, spear or sword warrior.. well i have no idea
At the moment i use my sword as have palleck 3, if i had firelash 3 then i would use my axe i think
So i use the weapon which suits my scrolls and when i get my 6 points to use on strength or dex i use then to suit what upgrade i can use from my storeage box be it armour. helmet gloves or new weapon.
I do have a chaos axe now but need more strength to use it.
Question is what level do i need to decide what type of warrior i will be ??
Degrade jewel.. I normally sell these for around 650K but i have a few of them in my locker.
If say i use on my chaos axe how much does it reduce the stre and dex
is it 10% ( and is this called mounting)
Lastly saph ruby and topaz I normally use on weapon but when i go to a new weapon do i still need to use jewels to improve it ? . seems i may waste my jewels if i change weapons often ?
Also how many jewels can i had to my Sword or axe ??
Thanks all
Wolfcub lvl 30
To be or not to be
WELL DUDE HERE IS HOW IT GOES
WHEN UR INCREASE UR STATUS PIONTS BY 3:3 FOR STRENGTH AND DEX EACH TIME YOU LEVEL UP, YOU ARE CALLED A SOWRD WARRIOR.
IF IT GOES BY AN ALTERNATE RATIO OF 3:3 AND 4:2 THEN A SPEAR WARRIOR.
AND IF IT IS 4:2 ITS A AXE WARRIOR.
U CAN USE DEGRADE JEWELS ON YOUR WEAPONS ANYTIME, IT REDUCES THE LEVEL OF YOUR WEAPON. BUT IF IT IS LVL 1 THEN U CANT USE IT, NOR WILL YOU LOSE THE JEWEL IF YOU USE IT.
YOU WILL GAIN MORE STRENGTH AFTER A FEW LEVEL UP, SO YOU CAN CHOOSE YOUR BUILD ACCORDINGLY. ALSO THERE IS NO PARTICULAR REQUIREMENT AS TO WHEN U BECOME A CERTAIN WARRIOR.
RUBIES SAPPHIRES AND TOPAZES NEED TO BE USED ON A WEAPON OR ARMOUR ONLY THE FIRST TIME YOU WEAR IT, ITS NO COMPULSION EXCEPT THAT YOUR ELEMENTAL ATTACK INCREASES.
THERE IS A LIMIT TO HOW MUCH RUBIES N STUFF CAN BE PUT ON YOUR WEAPONS. ONCE U HIT IT, YOUR ELEMENTAL ATTACK OR DEFENCE REDUCES TO 1 AND U CAN NO LONGER ADD ANY FURTHER JEWELS, BUT DJS AND UJS STILL WORK.
UNDER WARRIOR SECTION I HAVE POSTED WARRIOR BUILDS AND THEIR
PLUS POINTS AND PROBLEMS.
SELECT A BUILD AND TELL ME YOUR LEVEL, I WILL HELP YOU ADJUST THE SAME HERE.
hi
Thanks for your advice allajaxnamjo wrote:might i also suggest that u not use any of the warrior spells while killing creeps...just wastes mp and not to mention hp as the creep takes longer to die...
a warrior needs no mp till freeze...its just a waste of time...
AJAX
Ajax you have confused me ......
I use spear at moment and if i attack a certain creep i hit with say 80-90 attack power
If i use my spear "spell" I attack with 95-125 ( i see attack level this as it shows when i hit monster)
It does use mp but it helps me kill them faster ( like killing gerges as so many attack same time, so i need high power for a fast skill)
This is the point of having scrolls ?? so not understand your comment
brad ajax is rite wen normal hit does 70 dmg and ur special does 95 there is a diff in tht bcos by the time u hit 1 special shot u wud have hit 2 normal shots meanin 2 normal shots u time = taken for 1 special shot or as u call it skill shot so instead of 140 dmg u wud be doin only 95 dmg so stick to ur normal shots
hi
Hi Guys
Hope you all having fun playing, i am my wife always know where i am these days ... on the damn computer hehehehee.
Must admit I do use spell attacks and they do help when i get mobbed as they kill faster fighting in R1
Just a quick question to lazy to work it out for myself hehe
but at level 50, what roughly should my stats for an axe , spear or blade warrior.
I am thinking to be a spear Warrior and hope to carry a sword for freeze i was a bit of a blood warrior but have used my lore to adjust.
I have about 15 points to use up on strentgh and dex
damn and i cant remember what my stat are now lol . tired eyes @@
but just give a rough idea level 50 for spear what stats should be like
thanks all
need my bed lol
wolfcub
thanks all
need my bed lol
wolfcub
