need sm info on merce's for archerz character
which merce is best suited for bossing and d distribution of the stats
i know an archer merce is gud for pkin wid hustler lvl 10
i hv an archer merce lvl 67 wid hustler lvl 9
can i go bossin wid an archer merce or do i have to raise a new merce,if so plz gv the stats distribution
						need info on merce
Hi Monaliza,
For bossing:-
1. Archer Merc -> If you are hitting a high level boss, hustler and fatality can help you finish boss faster ... so max fatality too
2. HK Merc -> Max out antimagic and evasion ... this will increase your chances of evasion from magic and normal attacks
3. Warrior Merc -> Use the merc to tank the boss, and you hit from a distance. Make sure that your merc has maxed pants for evasion n magic evasion.
4. Mage Merc -> Awesome damage at G8+ levels.
The choice depends on how you want to boss.
For solo bossing, i prefer Archer Merc
If you have someone else to tank, go with Mage Merc
If you like to tank n hunt bosses, go for HK merc
							For bossing:-
- god_mode_xstyle
hmmmm
What netdemona said was allright but ...
For bossing Warrior mercy is best fo ARcher ... as warrior mercy is high on deffence and offence both .. gives high damage .. and tanks boss for a long time and using that .. archers can kill boss from distance eaisy.
and also warrior mercs blinds and piers (stuns) bosses
yes its true ... that warrior merc can stun boss... i have allready tested on C3 boss ...
anybody who wanna see c3 boss getting stunned by a 106 lvl warrior merc
is most welcome to pm in game (IGN: Technokid)
for warrior mercy u should max Stun and Pier after that try to max elemental blow.
however i feel warrior mercs are best after G8 ...
Mage , Archer & HK mercs are great ... from the starting lvl .. but at high lvl .... warrior mercs become all best ...
so if u can tolerate the pain of growing warrior merc .. then i should suggest .. warrior mercs are the best mercs for bossing and hunting
				Sandeepkille
i will prefer archar mercy bcz its rox in pking as well as bossing . warrior mercy is suitable only for mages to tank bosses bcz mages have less defence, also warrior mercy gives extra elemental attack which is helpful for mages . warrior mercy is only and only  works in tanking and not for pking.@ monaliza, dude hustler is not everything,u must increase  fatality also, according to me both has equal importance.so if you have mage char go with warrior/hk mercy, if u have archar go with archar/warrior mercy, if you  have warrior char go with archar mercy, and if u have hk char it depends upon you bcz hk suits all type of mercy.
						@rickyrox
thanx dude
i know hustler is nt everything but u should have noticed d level of my merce itz 71 nw.I am working on fatality too and have it at lvl 4 nw. i'm puttin all my ms points into fatality n try to increase it to atleast lvl9.
Well guys,
I hav sm questions:-
(1):- Which is the most important merci for archers ?
(2):- I hav 3 merci... mage (lvl 91), archer (lvl 75) and HK (lvl 61). Do i hav the required mercies for an archer ?
(3):- (Most important) I m thinking to make a warrior merci so i decided to NPC mage merci. Shud i do ?
@ Oblivian
Few months back i came to know that u hav all 4 mercies.
and all above lvl 110.
Is it true ?
Can we hav 4 mercies ?
And if yes, then we hav to keep 1 merci on everytime time.
And how can we go to pvp as 1 merci will be on everytime and there are only 4 space to keep our merci (3 for off and 1 for on) ?
@ Oblivian
Is it true ?
