increase u r speed of gaming new trick
did u r get the speed?
yes i got a little bit increased speed
3
30%
no nothing happened
7
70%
Total votes: 10
Mscore
Post by Mscore »
hi friends,
1. Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
Once you have done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
bye,
Gokul.s 8)
DEATH AWAITS YOU ANYTIME - BEWARE....!
I AM BACK ........!
I AM NOT ALWAYS RITE BUT NEVER WRONG..!
IGN-MSCORE (AM an Noob Helper)
danishheaven
Post by danishheaven »
no need ...the default PC (windows configuration is enought)
dont opt for suck kinda stupidity! You will surely land up with ur windows problem !
bTW ... ITS WORKS .. :d
Moonflower
Post by Moonflower »
its safe if u kno wat ur doin bu if U do not kno ur way arnd d PC thn dun do it !!!
p.s. not much of a diffrence max 5% bu scrws up sm apps !!!
if u wanna go ahed wid these make a "SYSTEM RESTORE POINT"
Cavalarcher
Post by Cavalarcher »
cool `Helped a bit
IGN: Cavalarcher (Xbow)
IGT: Spiral Darkness (My own KH)
IGL: 12x (No more leveling)
College life started... Diploma in Civil 1st Year... Sad can't play any more
Mscore
Post by Mscore »
Note: If a bandwidth limit is set for a particular network adapter in the registry, this setting is ignored when configuring that network adapter. This usually happens if anyone is using third party DSL/ ADSL connection booster tools like TCP Optimizer, DSL Speed, etc.
I AM BACK ........!
Finaticgal
Post by Finaticgal »
Yeah we no need to use ur tricks....
ReST †n Peace™
THis †s The End Of Everything
