Want no LAGG HMM... i face no lagg's !
For no lagg firstly you should get less ping
Go to >Start Menu>Run>Ping 210.210.67.197
210.210.67.197
is the server Ip address!
The reply you would get should be Less than 150ms if its more than you will face more Laggs. the more the ping xxxms the more will be your lagg!
Do an experiment .. your friends might be having.different Internet connection. tell them to
you will get different results from your friends ! The result in which the Ping time is the least Opt for the same ISP provider!
i recommend Airtel.Sify(if available)
I use MTNL it rocks!
UPGRADE TO 1 mbps plan Or 512
even 256 kbps connection dosent causes lagg and gives enought speed if u get the right ISP
and regarding Internet speed you must contact ur ISP to provide you for more speed!(as per plans)
and tools are available on the internet for increasing and boosting ur Internet speed! But they are worth less! I had MYSELF Experienced
