hi guys/gals,
Iam a KN in level 15 n iam quite new to a3 ,i want to know whats the use of Lore points that they give once our quest is completed .What to do with it?. Some people say that if we kill some other players then our lore points will get reduce .So what to do with it?
Whats the use of Lore Points
who told you that???
Ur lore can reduce only two ways, if u jump nationality(which takes 10k lore
or if u adjust ur stats(str, dex, hp, mp yup they can be reduced by 1k for each point, which means u can redistribute that point amongst other stats)
Hmmm, In conventional RPGS, lore is used to help in identifying things..the greater the lore the greater the chance of identifying highher and highre level artifacts..(which kinda makes sense..Lore=knowledge)
Not so Here: I dont see any other use of lore...which is silly..lore needed to adjust stats..hardcore RPG gamers will mostly concur with me
Well Aldor,,
To add to ur limited knowledge of lores :p ... in A3 the lore is used up in another way - when u create a Knighthood, the leader needs to use up 30K lore.
Also all Special quests have lore requirement. If you open ur quest window and goto the special quests tab and browse through all the special quests you will see diff lvls of lore requirement! Ahem
Ilostmyshue
Darkshadow
Thanxs for ur Replies
hi guys/gals,
Thanxs for ur replies guys now i understand what to do with it .If i have any doubts i ll clear with u guys/gals later.c u
Thanxs!!!!
Thanxs!!!!
dude chief
dude do we need 30k lore points to create KH .
askin coz i am lvl 75 and aftr 15 more lvl i can create my KH
