Cannot start game...
"Hey what do i do?"
Noefius
Post by Noefius »
i just installed the game aND THAN CLICKED ON THE exe client and than the little a3india updater window pops up and it says ..cannot get version information from server...what doi do now?
Requeimnh
Post by Requeimnh »
send a mail to a3 guys hopefully they'll know what to do
eapenster
Post by eapenster »
man i asked them i also have same problem and they wont answer.they said first to reinstall and all. i reinstalled redownloaded re registerd did everything but it dsnt work.they could easily keep a downloadable patch exe for us but nothing till now :cry:
Requeimnh
Post by Requeimnh »
that probabaly means ur portsare blocked .Most ISP's block ports so just ask them to unlock ur ports.
Cybele
Post by Cybele »
Uh you should probably connect to the internet first then ope up A3.. if that doesn't work check for a firewall ...
Ajax
Post by Ajax »
Shadowfaye wrote:Uh you should probably connect to the internet first then ope up A3.. if that doesn't work check for a firewall ...
i had the same problem but after havin tried everytin i still couldnt make the game work. So now its only Cafe-Play for me.
Cybele
Post by Cybele »
Weird... talk to your ISP then ? Which one are you using ?
Ajax
Post by Ajax »
Shadowfaye wrote:Weird... talk to your ISP then ? Which one are you using ?
Im using Net4india Broadband and suprisingly RO does not work on the comp too
Requeimnh
Post by Requeimnh »
your ports are definately blocked.Ihad the same problem earlier.
Cybele
Post by Cybele »
Definitely a problem with the ISP then. I think Sify knew this was going to happen , which explains the presence of the Sify gold discs in the boxes.
