HI GUYS...
I've seen mages gettin around .10 to .18 per cynick at 110+ lvls...
They got this increased EXP by doin a combo attack on the cynick..
1.)Stigma
2.)Sleep
3.)SB
TRY IT OUT....THIS WORKS....
Well...the reason i posted this is well..does any1 know any tricks like these other chars can use for lvlin??
If yes then pls share it with us...
Thanx a lot
						GETTING INCREASED EXP FROM CREEPS
What you are talking about is not due to skill combination but its due to overkill.
It's like if a creep has HP of 10K and a mage does SB dmg of 2K on that creep, so she will need 5 SB attacks on that creep to kill it. But if the last attack is crit then she will do a damage of 4000 while the creep has only 2000 HP left. In this case, the mage will get extra XP for overkill.
With Cynick, one SB is enough to kill it. But if you hit it first with stigma or even fury, and then attack with SB, you will get overkill and you will get more XP. This is appliacble with almost all creeps and not only cynicks. I have personally noticed this happening more with rangers in S3 & S4 if my last shot is crit.
i was the one of the first who first noticed and told about this to friends.
it's called over hit exp.
the thing is cyniks have 1000 HP
if u give it any damage about that 1000 point , u get that as bonus
for example
if u get 0.02 per cynik. if u stigma it(does around 600-800), and then SB it(giving added 1000). so total u do is 1800
exp will be 0.02 x (1800/1000).
works with other creeps also, but, works best on cyniks as they have least HP.
Hope it helps. and this ain't a bug , it's a game feature.
i still am able to squeeze out 0.03% from cynik on critical hit when i was around lvl 130( had a booster of course, booster helps when exp gained from them when solo reduces below 0.02% per kill on normal hit, usually)
for example
