HI GUYS...
I've seen mages gettin around .10 to .18 per cynick at 110+ lvls...
They got this increased EXP by doin a combo attack on the cynick..
1.)Stigma
2.)Sleep
3.)SB
TRY IT OUT....THIS WORKS....
Well...the reason i posted this is well..does any1 know any tricks like these other chars can use for lvlin??
If yes then pls share it with us...
Thanx a lot
GETTING INCREASED EXP FROM CREEPS
Hmmmm.......
are noobs cynicks give a good exp ra.Man u are having a mage and u dont worry. u need only one sb for cynicks da. And u may get good drops for that. Are Abshiek what will u do when the cynicks will come closer , will u sleep or close ur eyes that to see the magic of decreasing -2% ha ha ha ha
Omg what a bunch of noobs
Such topics are all over the forums plz try to read arround for once then comment.
There is a post of prem i suppose if i remember correctly that he was getting abt 0.03 from cynic with a booster of lvl 110 where as other will get 0.01 with a booster of lvl 110.
Basically the exp gained increases significantly if the damage done is far higher than the HP bar of the creep.
Thanks
Cheter
Cheter
Ages old topic...and discussed many times. Just for the benefit of the people who said that this is useless....this is called overkill. When ur damage is more than creep's HP, you get more XP. If normal SB attck on Cynick will give you 0.01 XP, then stigma plus SB on lvl 110 will give you around 0.02 XP. This is not only applicable for only mages but for other classes too (with only exception of warrior I think). This is applicable on all creeps but as Cynick's HP is quite low, you wil get increased XP almost 90% times.
Bah!!
Cynick is one shot dead for me if i ewen stigma Him with g1 staff..
so the Stigma+Wip+Sb
wont do any help to me..
can any one hav any other suggetion??
I Rule My Destiny
And My Destiny Rule's You!!
Call me "'rAy'"
IGN - Roguecontrol [Mage 150+ : Aura soon]
IGN - Yufa [Mage : Aura]
Dosn't Looks Like i wuld be Aura3 on this server Ewer!!
Call me "'rAy'"
