Di Phameino
- Level : 135
- Offensive Power : 700 - 1200
- Defensive Power : 500
- Physical Strength : 100000
- Property : Lightning
Let me know in case I have a HK with me. What shiled should I ask him to put, Ice,Lightning,Fire?
What if I had cruise, ice fire r lighting which one to use?
Took Di Phameino for just example.
Further I heard that you use certain shiled in certain maps, not sure of that, is it Ice shield(not sure which one to use just example) in Selvarb coz its freezing there, something like that? and what abput in other maps.
Hope you guys understand what I am trying to find out.
-Sant(Sword Warrior)
What shields and elemental attack to use against monsters.
LIGHTNING SHIELD OF COURSE!!!
THERE WAS ALSO A THING THAT ONE PARTICULAR SHIELD WORKS AGAINST THE OTHER PROPERTY, EXAMPLE A LIGHT WILL BEAT FIRE, WHICH WILL IN TURN BE BEATEN BY WATER OR SOMETHING LIKE THAT
*don't remember the proper order now*
SO I SAY GO GET A LIGHTNING SHIELD IN TOWN AND GO FOR THE BOSS AS YOU WILL GET IT IN ONE TRIP AND PROBABLY WITHIN THE DURATION OF THE SHIELD. THIS WAY YOU CAN SAVE YOURSELF FROM DROP STEALING BASTARDS.
BUT I WOULD WANT YOU TO KEEP IN MIND ONE THING, THAT WHEN YOU GO TO KILL THE BOSS, YOU WILL BE MOBBED BY OTHER MONSTERS NAMELY, YAHGONS, ES, EWWEALIA, HAUTZ
WHICH HAVE PROPERTIES ICE, ICE, FIRE AND LIGHTNING, SO IF THE DAMAGE DONE PER MINUTE BY THESE MOBS IS HIGHER THAN COMPARED TO THE BOSS THEN I SUGGEST YOU GO FOR LIGHTNING OR ICE SHIELD.
IF YOU DIDN'T BOTHER TO READ, MY CONCLUSION IS LIGHTNING!
