i can connect to A3, go into raydan server, select my character(Zoid), and then comes the problem it shows loading(with the warrior image) and then nothing happens the map is never loaded.
i dont know what the problem is with A3 and our ISP. all those people who use this ISP cannot connect to A3. the sole reason we stick to this isp is because the rates are cheap and the download speeds are good(not fluctuating like other ISPs).
All i can say is My ISP uses a backbone of Reliance and VSNL (dedicated line). which is then distributed to us via a proxy server(which is setup at the cable operator guy). i have spoken to my internet cable operator and there is no port blockage.
P.S. Ragnarok seems to work fine(even International Private Servers)
A3 Shut for almost 3 weeks now!
Man this sucks!!
Missing you guys... it was fun reaching lvl 50 with you guys.
The other day ur char spawned in town center.... but when i wispered you did not reply for quite some time till ur char dissapeared again.
Did you try connecting from some other place? try it from some friend's place or gaming cafe and c if the same prob occurs.
Wht are the GMs saying?
