Server lagging badly and gettting dced
hello players and gms .. the server is lagging i am pinging to a3server its gving timeput whereas yahoo going good
- Attachments
- ping.JPG (127.13 KiB) Viewed 5037 times
- Gmstorm
- A3 Gamemaster
Re: Server lagging badly and gettting dced
Could you please provide us with the name of your Internet Service Provider so that we can diagnose the issue?
Borninsane
Sir i am having the same issue since 3-4 days only, i never had this pings fluctuation since years with my service provider and server as well even during hyderabad flooding time. I already discussed with my act fibernet technicians they already came to my house and checked the wiring, cmd reports and everything else they could from their side, everything is NEAT!
Only when i ping to services.a3india.com i get packet loss maximum 6% minimum 2%, still its an issue i used to have 15ms constant pin and rarely it goes up to 31 ms. If its at least little convenient with that packetloss i wouldnt be even writing this post here, in the morning time its normal like it was usually, 0% packet loss and constant 15ms ping, in-game lag starts from afternoon and then i get 4-5% packetloss, i have been checking cmd reports since 3-4days. I am sending one of my cmd report.txt please check once, server is also hosted from hyderabad ACT office right, so please try to communicate with them to know whats the issue or if you could fix it from your end. I tried everything from my side im just relying on you guys now
Kindly reply with whatever solutions you have, i have done a full scan on my laptop as well, i use windows 10 and no threats at all, i did because sometimes malware also affects ping and packet loss. So whatever it is its up to you now
Pinging a3india.com [202.53.11.53] with 32 bytes of data:
Reply from 202.53.11.53: bytes=32 time=28ms TTL=56
Reply from 202.53.11.53: bytes=32 time=30ms TTL=56
Reply from 202.53.11.53: bytes=32 time=29ms TTL=56
Reply from 202.53.11.53: bytes=32 time=27ms TTL=56
Reply from 202.53.11.53: bytes=32 time=49ms TTL=56
Request timed out.
Request timed out.
Reply from 202.53.11.53: bytes=32 time=65ms TTL=56
Reply from 202.53.11.53: bytes=32 time=76ms TTL=56
Reply from 202.53.11.53: bytes=32 time=111ms TTL=56
Reply from 202.53.11.53: bytes=32 time=36ms TTL=56
Reply from 202.53.11.53: bytes=32 time=42ms TTL=56
Reply from 202.53.11.53: bytes=32 time=38ms TTL=56
Request timed out.
Reply from 202.53.11.53: bytes=32 time=61ms TTL=56
Reply from 202.53.11.53: bytes=32 time=39ms TTL=56
Reply from 202.53.11.53: bytes=32 time=31ms TTL=56
Reply from 202.53.11.53: bytes=32 time=33ms TTL=56
Request timed out.
Reply from 202.53.11.53: bytes=32 time=69ms TTL=56
Request timed out.
Reply from 202.53.11.53: bytes=32 time=83ms TTL=56
Reply from 202.53.11.53: bytes=32 time=57ms TTL=56
Reply from 202.53.11.53: bytes=32 time=58ms TTL=56
Reply from 202.53.11.53: bytes=32 time=47ms TTL=56
Request timed out.
Ping statistics for 202.53.11.53:
Packets: Sent = 104, Received = 98, Lost = 6 (5% loss),
Approximate round trip times in milli-seconds:
Minimum = 27ms, Maximum = 111ms, Average = 32ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
- Gmstorm
- A3 Gamemaster
Please try to ping actcorp.in and acttv.in and post the ping reports.
Borninsane
This is act portal!
Pinging actcorp.in [202.53.8.32] with 32 bytes of data:
Reply from 202.53.8.32: bytes=32 time=33ms TTL=55
Reply from 202.53.8.32: bytes=32 time=36ms TTL=55
Reply from 202.53.8.32: bytes=32 time=32ms TTL=55
Reply from 202.53.8.32: bytes=32 time=34ms TTL=55
Request timed out.
Reply from 202.53.8.32: bytes=32 time=35ms TTL=55
Reply from 202.53.8.32: bytes=32 time=50ms TTL=55
Reply from 202.53.8.32: bytes=32 time=37ms TTL=55
Request timed out.
Reply from 202.53.8.32: bytes=32 time=41ms TTL=55
Ping statistics for 202.53.8.32:
Packets: Sent = 75, Received = 73, Lost = 2 (2% loss),
Minimum = 32ms, Maximum = 50ms, Average = 33ms
This is actportl
Pinging portal.acttv.in [202.53.8.52] with 32 bytes of data:
Reply from 202.53.8.52: bytes=32 time=33ms TTL=54
Request timed out.
Reply from 202.53.8.52: bytes=32 time=34ms TTL=54
Reply from 202.53.8.52: bytes=32 time=32ms TTL=54
Request timed out.
Request timed out.
Reply from 202.53.8.52: bytes=32 time=38ms TTL=54
Reply from 202.53.8.52: bytes=32 time=35ms TTL=54
Reply from 202.53.8.52: bytes=32 time=36ms TTL=54
Reply from 202.53.8.52: bytes=32 time=39ms TTL=54
Reply from 202.53.8.52: bytes=32 time=37ms TTL=54
Reply from 202.53.8.52: bytes=32 time=62ms TTL=54
Reply from 202.53.8.52: bytes=32 time=41ms TTL=54
Request timed out.
Request timed out.
Ping statistics for 202.53.8.52:
Packets: Sent = 155, Received = 150, Lost = 5 (3% loss),
Minimum = 32ms, Maximum = 62ms, Average = 34ms
My location divison head had told me to tell the a3india management to raise ticket to hyderbad act fibernet so that they might check the path and theres definitely a line choking issue. Its fine from cheanni to nellore gateway side itseems, my location is nellore
Request timed out.
Request timed out.
This is actportl
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Borninsane
Sir these are the ping statistics for a3india, actportal and intermediate ip in the morning, please check!
Packets: Sent = 387, Received = 385, Lost = 2 (0% loss),
Minimum = 22ms, Maximum = 160ms, Average = 24ms
Ping statistics for 183.82.14.222:
Packets: Sent = 442, Received = 442, Lost = 0 (0% loss),
Minimum = 20ms, Maximum = 102ms, Average = 22ms
Packets: Sent = 723, Received = 723, Lost = 0 (0% loss),
Minimum = 21ms, Maximum = 253ms, Average = 24ms
Theres not even single millisecond fluctuation right now in the morning, you see hows it working! But when i get back by 8pm and when i sit to play, it all starts there and lasts till i sleep i.e 12pm don't know if i would still get packet loss after that time. ISP is blaming game, game is blaming ISP. This is unfortunate for me
- Gmstorm
- A3 Gamemaster
You are having packet loss to your ISP's website. It's pretty surely an issue with your ISP itself.Borninsane wrote: Ping statistics for 202.53.8.52:
Borninsane
That is common for them itseems,
but actually the issue is fixed they called me today and said there was some choking issue in the previous path we applied for new static ip and now your path has changed, the ping is reduced and no reuqest timed out now. Accordingly i checked it seems fine now yeah the ping has reduced to 16ms and sometimes i get 0ms as well, but for 15-20 mins i get 1 ping rise to 300+ms and gets back to 16 not consistently but quite rarely. Still its playable it could affect me in wars though, but something is better than nothing. So cheers
- Gmstorm
- A3 Gamemaster
This is NOT normal. Your ISP seems to be facing issues internally. You should contact them with the ping reports the ISP's website and portal pages. It's very unusual to get packet loss to a local website hosted by your ISP.Borninsane wrote:That is common for them itseems,
