Sword HK Passive Skills
Hey can someone guide me for passive skills for sword HK, ofcourse sword HK does not need armoury so what other passives should be taken other than Roubst & Sword mastry...........suggestions awaited
See, here's how a3 works
Imagine Ur HP bar = 500, opp dmg = 500, ur def = 250.
So when he attacks u he will do 250 dmg on u i.e, 500(his atk) - 250(ur def)
Hence u will lose 250 HP.
Supposing Ur Hp bar is 300 and his attack is 500 and ur def is 400,
he will do around 100 dmg on u. (same logic)
So hope u get the idea?
There is also the elemental attacks etc. which u can worry about later.
Hence if u have a decent enough HP bar then u can concentrate on def.
What people believe (very sadly) is that if u have a 3k bar, u can tank all.
If u have 3k def, even aura chars will get 0s on u ( hehehe)
Go normal if u r a swordie, wear mace pants for acc, make ur def as high as possible.
If u intend to go mace, go blood after g10(u cant block the dmg, then learn to tank it )
oh yeah, dont flame for the abovve post( i dont see any one post here much anyways, but just in case)
There are a lot of other variables also as far as dmg calc is concerned.
A sweet example is, even with G10 u go n stand in memora field for a while and u will see memoras also do dmg on u(a little, but they do, i tried it with many chars)
