ok , lets say i reach g 10 stats ( lvl 140 ) . from level 141 , in what stat shud i add them in ? since i am a swordie , should i put all stat points in STR - to go synchro & get my STR to that of G9 Macer ? OR shud i add the stat points in Vitality ( HP ) and go Blood ? OR should i just add stats to STR & DEX as usual ( 3 + 3 ) ?
please give your suggestions . . .
what to do with the stat points from level 141 ?
{ IGN: Ahtnaver }{ IGC: Sword HK @ Q }{ KH Leader: ÇØV€ÑÅц }
Well, the answer depends on the type of game you want to play.
My suggestion:
1. Go normal sword stats till G9
2. Go blood from G9 till you reach 157
3. At 157, remove points from blood and add to strength. At this stage, you will have enough STR to wear a G9 mace pants. This will give you much required accuracy and evasion
4. When you do change to STR from VIT, make sure that you take robust lvl 6.
Hope this helps.
Cheers!
hemu
My suggestion:
Hope this helps.
Cheers!
hemu
to caval & net ,
thanks for the info guys , but i'm still not convinced . . .well , if i start goin blood from 131 ,what about the g 10 stats ? cant i take myself to 140 stats so that i can wear G 10 sgield & then go blood ? hmmm , anyway , still a long way to start scratchin' my head about that . . .
still , i need more info on what to do . . .
later . . .
later . . .
Well... dude
See !
As Hemu and I said to put ur points in vitality... and u saying u wanna use g10s... but dude g10 is far ahead (u urself said) so go blood from G9... and suppose in case if u made any g10... then only remove points from blood... thinking long before to use g10 wont b useful...
Only whn u make a g10 then cm out of blood... till then remain in blood coz that will be the best.
See !
You need 6 Graces to make full G10 ... or else you will be stuck with G10 shield. The additional defense provided by G10 shield does not warrant loosing 10 lvl blood.Cavalxxx wrote: Only whn u make a g10 then cm out of blood... till then remain in blood coz that will be the best.
Hemu...netdemon wrote:You need 6 Graces to make full G10 ... or else you will be stuck with G10 shield. The additional defense provided by G10 shield does not warrant loosing 10 lvl blood.Cavalxxx wrote: Only whn u make a g10 then cm out of blood... till then remain in blood coz that will be the best.
I didn't said full G10
