Guys
i wanted to ask how do we put items in storage............................
Storage...
Go to NPC Mecho if you are in Quanato and click on open NPC window. That should lead you to the large hall/basement , in the corners of which are two boxes. Click on the boxes and you will get your storage window. It costs 500 woonz to put anything in so make sure you have cash before you go in. Also you can deposit and withdraw wz by clciking the deposit tab ( the second one on the top ). when you are done , you should see a staircase on one of the walls run towards it and your cursor will change from to a red circle with an arrow , keep running and the screen will change to show you out side in the main map again. Hope you dont have any problems after this.
thx dudeShadowfaye wrote:Go to NPC Mecho if you are in Quanato and click on open NPC window. That should lead you to the large hall/basement , in the corners of which are two boxes. Click on the boxes and you will get your storage window. It costs 500 woonz to put anything in so make sure you have cash before you go in. Also you can deposit and withdraw wz by clciking the deposit tab ( the second one on the top ). when you are done , you should see a staircase on one of the walls run towards it and your cursor will change from to a red circle with an arrow , keep running and the screen will change to show you out side in the main map again. Hope you dont have any problems after this.
