Hi guys....
I hav created a mage in A3...started a day ago.....she is lvl 8..havent been playin much though....
Anyway..here my question....
Q1>>Wat is the difference between elemental staffs and non elemental staffs....
I had a Rhen Staff when I started...but got a Khall Staff later (as a drop)
But there seems to be no difference ..I am able to use both elemental and non elemental spells with both of them....Plzz tell me the difference...
Q2>>Someone plzz explain this table to me....I mean including upgrading weapons to higher levels.. wat does the last three columns mean..
LVL Requirement Damage Max Elemental Damage
Int. Dex. Min Max Ice Fire Lightning
I 26 12 15 18 3 3 3
II 35 15 19 23 4 4 4
III 44 18 23 28 5 5 5
IV 53 21 27 33 6 6 6
V 62 24 31 38 7 7 7
VI 62 24 39 48 8 8 8
VII 62 24 43 53 9 9 9
VIII 62 24 47 58 10 10 10
IX 62 24 63 78 15 15 15
X 62 24 79 98 21 21 21
How does the weapon upgradation happen....???
Help on Weapons----Plzzz
A staff becomes an elemental one when you attach the gems to it. Sapphire is for Ice , Ruby is for Fire and Topaz for lightning. Until you do that you cannot use your elemental skills with a normal staff.Q1>>Wat is the difference between elemental staffs and non elemental staffs....
Re: Help on Weapons----Plzzz
If u dunno how to make it elemental then take the staff in the inventory(out of the equips) now click on the stone(Saphire,Topaz,etc) n drag it to the weapon!satanis131 wrote:Hi guys....
but i thought we can use only 2 gemstinkerbeast wrote:Adding 3 different gems on the same staff worked for me, if that's what you mean.Shadowfaye wrote:Plus usually if its a Rhen or a low Khall then using one of each should be enough. I haven't found how you can equip two of the same type of gem to each staff. maybe you need an upgrade ?
