Cannot get Version information from server
"Hey what do i do?"
Ajax
Post by Ajax »
Hi guys,
i installed A3 and on running the .exe file the above error.
Some guy here told me to check with ur ISP if all ur ports are open.
I am using Proxy between the two comps at my home so if someonecan tell me whter the ports between these two comps r blocked or between the ISP provider and our comps
and which ports r blocked
I tried to post q query but whenever i click submits i get to the top of the page and nothing happens
The game starts on the main comp but as its graphics r low it closes down , but it does not even start on the other comp giving the above error
Requeimnh
Post by Requeimnh »
we cant tell you that you just have to ask ur ISP guy to open all ports or ask tech assistance which specific port to open.
Keiser
Post by Keiser »
errr.. have you checked whether you are in the offline mode?
Check you internet explorer and make sure that you are not in the offline mode. I get that message only then
Cybele
Post by Cybele »
Yep I get that when I'm not connected to the internet. Check whther you are and whether your connection is fast enough to support this game.
Ajax
Post by Ajax »
Shadowfaye wrote:Yep I get that when I'm not connected to the internet. Check whther you are and whether your connection is fast enough to support this game.
i hav a 100mbps connectin dude
Requeimnh
Post by Requeimnh »
Dude that's your LAN connection speed not your ISP speed.
Ajax
Post by Ajax »
mavericknh wrote:Dude that's your LAN connection speed not your ISP speed.
ohhhh
Requeimnh
Post by Requeimnh »
Ajax
Post by Ajax »
but whts the use of tht
