For all of u who are still arguing about this here is the bottomline...
At the same level me(mace) and Raph(swordie) we removed full set, merc and shue and tried damagae on each other. It was exactly the same... So it implies A sword HK = Mace HK, the only difference arises with ur set and weapon and shue and merc. Well If u do not belive me just Call any HK of ur own level and of different build(if u r sword call a mace HK and vice versa) and try what I have mentioned. So basically its the same in PvP. The only diff is in hunting creeps wherein I do more damage and he does less. But I lose more pots than him. Even then we are equal. I will Explain how, Suppose I can kill a creep in 5 shots suffering a loss of 300 HP, he can kill the same creep in 8 shots, but he also loses 300 Hp, because even though he has more dex he takes longer time to kill a creep, which means he loses HP. SO in the end a mace HK = Sword Hk, the difference arises in Only "SET, SHUE & MERC"
If u did not understand my post please post here, I'll try to explain better
							Which Knight is better???
- Hakuronsama
well if he kills a creep in 8 shots an u kill a creep in 5 shots by losin da same hp den isnt mace better???
and if one is amce an oder is sword an both removed weapons an armour how da hell can u get da same damage.....the mace hk will be hvin much more damge den da sword hk.....
lol watevea u posted is alll craapp
Er dude, If u dont believe me go check it ureself. I will again try to explain how it works, See, Mace Hks have more attack, but swordies have better def so we do lesser damage on em than on others, similarly swordies have lesser attack power, but they do more damage on mace HKs cause mace Hks have sad def. I hope u can understand now.
Secondly as far as killing creeps is concerned again mace Hks suffer same damage from creeps(in terms of pots lost) as swordies but only difference is time, mace Hks are a bit faster(more dmg) but consider a boss, say a tough one, like khanien, mace Hk does more dmg but has to tp early cause he uses pots fast, swordie empties pots later but he also has to tp because his damage will not be sufficient. Dude the game is programmed in such a way that all classes of chars and all chars are equal to one another. all have + and - . only diff is ur style of gameplay and ur set/merc/shue opts.
- Techoknightx
So u think tht sword HK = Mace Hk... how it can be possible u know naa the diff. of both mace & sword in DEFENCE its make a very large diff sword has more defence thn mace so he will get less damage thn mace and mace will get less defence so e will approx damage of sword + str.
At high lvl u will get the diff in both u just it out man sword is betterthn mace after 140lvl sword Hk can do changes in stats i.e all str or dex or 3:3 or blood. so if he puts all in def at time of B.O.R he will get more def thn tht of mace one tht also u check it WITHOUT SHUE MERCE STUFF..
thn u tell me & if he goes in blood its np or in str he can use G10 mace normal at lvl155 (NORMAL) or normal stats thn also its good for him he will get both but he will give less damage thn mace one
If u think u have better sugestion thn these thn plzz tell me
dude I waS not referring to going blood or anything, I am talking about basics, I agree sword HK set can have more opts etc. but as far as ur point is concerned at lvl 155+ a mace HK can use a swrd G10 set. That way he will have killer attack and a sexy defence. See, there are many ways by which u can keep arguing mace> sword or sword > mace, but when it all boils down to the fact that in the end all that matters is ur gameplay, options on set and bird etc.
				Smartvishal
				Chorbazaarr
- Techoknightx
				Chorbazaarr
- Bloodyxoid
