Worked wonders for me..Thanks again
The Lord for President!!
All hail!!
It;s Usually disabled/Not Enabled from default. many of you ppl who will go to change that... will notice it.. neverthless change it to 0% after enabling it.Zangetsu wrote:hope this might help as well.....
Goto Start---> run --->(type) gpedit.msc
When the screen opens ......
There will be two options 1.Computer Configuration
2. User configuration
Choose Computer Configuration --> Administrative Templates ---> Network --> QoS Packet Scheduler
In that double click Limit Reservable bandwith and
Enable it and give the bandwith % to 0(zero) or 1 may be.Ur Internet performance is made relatively faster now.
Microsoft reserves 20% of ur bandwith for automatic updates and that bandwith u have released it for ur use.
errr I do see tht text in tht file 2ktc... what to do after that ? reboot? what does this filr does..??? I hope whtever It does it removes bsnl laggg..Do the following:
Save the appropriate lines of text below to your Desktop in the file name 2KTCP64K.REG, and then double-click on the resulting file to add the setting into your Registry.
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"GlobalMaxTcpWindowSize"=dword:0000ffff
