Hiiiii.........pvp
- Vinamraghara
yeah true
for no ordinary reason they have tld HK's are godly.
If a player knows how to play HK then he can beat a warrior 3 levels above him for sure.that is the HK must have good options in pants and boots and good wep (lvl7 wil do).without cruise warrior damage is really too bad and with all the buffs of HK his attk goes really bad and there is nothing that he can do abt that.
for playing warrior dont even think of saying its tough,all u need to do is click on the char u want to pk and sleep or auto pot.its not the case of HKs
buff bufff bufffff BOR warat reduce 3 shots and the same continues.As
long as HK can heal and hit any warrior he can be killed easily.the case of potting means the warrior is high level and need some strat to kill him
Gaara noob used to pk warriors and mages almost 11 lvls above him .ie he was 104 and they were..u have to know the char to play one and be one
best is for mages in pking not in pvp use sed and sb simultenously and u can drain off hp pots frm ur opponent.
although radgebage can stop u frm that. coz u cant sed when smone uses radgebage on u. and for hks take their skills away and they will die like anything, coz real poor damage in melee attack.
the main point is
with a warrior u dont need brains to win a pvp
but if r a hk or a mage or a archer u need tons of it
am not attackin any1
but the thing is warriors are not as good as other chars are in pvp
am only talkin bout 100+ lvls
coz at this stage around 90% of the skills have been aquired
well every1 has give his point
every1 got his own technique
but the only thing u need is a good strategy
if ur a hk and archer vs warrior and a hk
well raz both and tell archer to fire
this is a basic strategy
well planed strategis u can see in the upcoming kh wars
say or not hks do well in pvp as they got raz and bor and they can remove each and every buff frm opponent
most of all same lvl mages are 1 shot away of aposple
Warriors do fine but the only thing they do is go attack and pot pot
Mages got more things to do
but once the hp abos is down they take huge damage
i cant say much about arcehrs
coz they only got run hit run hit
thats all i can say
plz no flames
thats all i can say
plz no flames
For archers biggest deciding factor is lag. U cant lag for doing hit n run in pking. Thats 1 reason y ppl from sify network do well with pking with an archer toon. If the same person gets a ping of 20 on sify and 100 on bsnl/airtel or 700 on private cable isps or overseas players (these are the pings that ppl actually get while playing a3) it will be the only deciding factor if archer is involved.
Dragonskull
destroyerz2
well u say after cruize 3 u cant stand boreddie_is_god wrote:agreed with entis most of the archers do hit and run, well entis after cruise3 bor cant stand.
but 1 thing wen a warrior gets cruize an HK gets Karnawpn
that means 20% more attack and 50% more ele
1 more deciding factor is a warrior cant remove bor or kw
but an hk can bug a lot
most of the fights b/w g9 hks and warriors i'v seen
hks win coz of heal bor and reduce warat
warriors cant remove buffs
thats the main disadvantage
if sm1 goes 1 on 1 no buffs only potting
warriors can whoop anybodies u know wat
