how do i get so much xp with premsundar
				Hardeep
Re: how do i get so much xp with premsundar
I know Tecno has replyed but i will like to present this topice in detail or clearly wid sm examples.sheshu wrote:hi guyz
i am totally confused in this matter i a 117 lvl mage when i am in c3 taxi party with premsundar and sm noobs i get 1% per 2 creeps wtf how is this can anyone telll me how dis happens
The concept is called "OVERKILL"
 The concept of overkill is as much a mystery as compared to dodge, defence and attack calculations in A3.
The 101 on Overkill is:
Assume 'X' as Hp of Creep
'Y' as Total Damage from Player
when Y>X the Difference as a % of Damage is given as EXP points.
EG: if a creep has 10k HP and the player does 9999+9999 Dmg the player should receive almost 99% more exp from the same Creep..
But this is not SO..
Mostly I have seen my Exp go up by at max 50% more exp.
So basically 150% exp per creep.
Best class to try this is MAGE cuz of massive SB dmg(most creeps are 2hits)
WHat you need to know to get OVERKILL BONUS
1> Your average attack range (prefer dex wepons as attack range is less variable)
2> Monster HP (so you can calculate your total DMG v/s Creep)
3> Critical hit rate (Easier on a crit locked class)
{For a non crit locked class Overkill Bonus would be received only if the last hit is a crit}
4> Thus calculate the DMG required to do over 110% DMG to creep
PS: You may also tend to recieve more WZ from creeps as they fall to Overkill DMG but this has not been verified
Maximum no. of time...overkill is done by mages coz of sb
normal sb damage goes to 3k
Classic e.g.
Cynick hp - 1k
Stigma damage - 900
Sb - 6k [crit]
it will get u lot more exp
and its applicable with creeps with low hp line
its damn tuff to get over kill exp frm a creep with gud hp line
like the s3 s4 creeps
best over kill works on cynicks
used to get sm 0.26% per cynick with a booster at 104 in a3 india
 . Hope THis Helps
				Zoroisback
