Hey Rex (Other knowledgeable players too,)
At level 40 a
a> Sword HK has 147 (strength) & 137 (dexterity)
b> Mace HK has 187 (strength) & 97 (dexterity)
Easy way to convert (if I am a Sword HK) is to wait for the next 20 levels (giving all my stats to Strength) and at 60 it becomes 267:137 (and I become a mace HK)
Can you please elaborate a little bit on how I convert from Sword to Mace HK using the Lore Point Scheme (say, I have the Lore points required for the conversion?)
Thanks a bunch in advance
Regards
Val
help out a noob.... stats for HK
Seems fairly straightforward: You need to raise strength by 40 and reduce dex by 40 to become a mace hk.
To begin with-you will have to reduce dex. Make sure u got 40k lore. (Do first part of R1 memora quest-300 lore-134 times to get this much
For each point reduced from dex, it takes 1k lore. Whatever u reduce gets added to the skill points counter. Now you can click '+' for str to increase that.
TO avoid confusion-remember this-it costs lore to increase the available skill points (which is obviously at the expense of your points under str dex vitality or mana). When you reallocate points, you are using up your available skill points-no lore is charged for that.
One potential caveat-see that you dont drop below the required level for the armor you're wearing, or it will pop off!
So i'd say its better that you have your mace set ready, and do the adjustment only after getting all requisite lore.
