wats the use of being spear warrior
				Timekeaper
Sword Warrior will survive hit from two other chars of the same level.
Axe warrior can survive only for few mins in the war between same levels. Sword warrior will lead the way to victory.(I mean total war not this silly wars in s1 and c1)
				Timekeaper
Hmmm....
Some points to take note.
3 types of warrior. Their main difference is that the damage range is different.
Although axe has a higher damage, the damage can go below the lowest of sword or spear sometimes. So as in the case of sword, the highest damage will nv reach as high as the axe.
In another words, sword produced a more constant damage. Follow by spear and then axe.
So which type you prefer... decide carefully. Cos when u are at higher lv... you will find that sword really give very low damage compare to axe. But the damage on every hit is constant.
Of cos the defence is another key point to decide too. Sword warrior definitely stay in battle longer.
				Assblaster
Axe warrior may have less def but he has more str. So all depends on hw mch potions u got. But offcourse sword warrior has the advantage of high def.san_thosh82 wrote:Sword Warrior will survive hit from two other chars of the same level.
