Spout has same range as that of Fury\stigma and 100% accuracy
In Magexs V Ole fight at 161...i wonder how many spoutrens went missing...spout has 100% success and in damage as well it rocks...
Mage can win but i dout against all warrs at same lvl....(sword,axe can fall easily though
The factor which is absent for warr currently is skill like mage's HP absorber and cruise cuts the bar half of the warr and hence lowers his tanking ability
-Endurance will recover the complete bar lost by High cruise
-High cruise gives tremendous attack compared to current's cruise which stands nowhere in comparison to make high dmg
-Valor will not allow mage to remove high cruise and gives a warr full opportunity to Hit a mage 1st in arena or map
- Now here is some bonus in warr's tanking ability
Endurance already gets warr's bar to normal while HC is on but Clotty blood turns on HP absorbing ability so when mage and Spear warr are hitting each other even from range fury\stigma warr will loose even lesser HP since HP is been absorbed
....Also Nidwhegro will ignore 10% dmg
So a warrior will loose some 60% lesser hp to a mage with ALL advance skills at lvl3..+ damage he will do with HC3...
So if some1 who have brain to use warr at the best of it's limitations can fight with mage considering all the points mentioned above he can win in arena\map.....
And thats y i prefer Spear warr ...better against archers,mages coz of range and spout...i never use SPOUTREN against any1...LAWL it takes xtra mp and 50-100 dmg more not much and missing atleast 5-6 outta 10 times if ur opponent is moving
