Thanks for taking the time for that reply man.Iguess ill stick to what you are doing.The reason i was doing what I was because i felt swordie does less damage.ANd I'm running for WOW when it's coming to Indiazchief wrote:Hey maverick if u making a swordie...then u need to stick to 3:3....coz the 4:2...will start giving u trouble after lvl 35.
Tip
If u really want to use both the weapons...like I am doing.. stick to points distribution for Sword class, at the same time look out for mace weapons with reduced requirements. For eg. I have a Renome sword and a War hammer and am using it at the same time as the War hammer has a 20% reduced requirement.
Somebody sold me that for 250K...i had the money so i bought it. the other difficult route is to use crafting to reduce requirement on higher grade weapons....difficult and risky as the weapon may be destroyed.
Therefore do not sell any extra weapons that u get. Use those for experimenting. Even if it gets destroyed you always have your main weapon intact.
Also it really doesnt matter which class you go for....as after lvl 80...you will hit the ceiling of the weapon and armors. i.e you wont be able to acquire new type of weapon or armor. You need to use crafting to develop higher lvls and grades.
Route 1 after lvl 80:
After lvl 80 you could choose to change ur points distribution to acquire mace weapons. So by lvl 100 you will have both Sword and Mace weapons. Remember acquire only mace weapons, do not go after Mace class armor as you will need a hell lot of upgrade jewels/Craft to keep your armor and weapon lvls up. Even going after Mace weapons will be at the cost of not upgrading your Sword and armor. If you go for a mix then you will have to distribute ur upgrade jewels/craft between Sword and mace type weapons and armor reducing the effective power of ur char for that lvl.
Route 2: aFter lvl 80
If you stick to being pure Swordie then you can invest all ur upgrade jewels/Craft on only one type of aromor and weapon and going on till you hit the ceiling for the sword weapon and armor. This will make your chars power optimum for that lvl. And then when you cant upgrade any further you go after Mace weapons.
Personnaly the best route is to stick to one class weapon and armor and go after reduce requirement for the other class weapon only so you get best of both worlds.
A question: Will you be playing so long????????????????????????
What if another game comes in India and everybody runs to that?
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Which Knight is better???
thatll be in a year or so ....i guessmavericknh wrote:Thanks for taking the time for that reply man.Iguess ill stick to what you are doing.The reason i was doing what I was because i felt swordie does less damage.ANd I'm running for WOW when it's coming to Indiazchief wrote:Hey maverick if u making a swordie...then u need to stick to 3:3....coz the 4:2...will start giving u trouble after lvl 35.
Tip
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm![]()
if this fight is just a matchup between u n me iam rdy for it..but it wont prove the strenght n weakness of our builds.. iam not close to ur lvl.....iam at 25 now.
if u want to find out for real go n fite someone ur size ...
as for the challenge .....guess i will take it.. after all lvl 25 swordi can mange a high lvl mace
Gaara
Gaara
