Hi all,
I wanna know the different kinds of shues i.e. u have shues that u can use from lvl 1 and shues that u can use from lvl 30 and shues tat u can use from lvl60
Wht is the difference between each of them?? is there any difference is properties?? or u get any special hidden prop?? or any way ur XP is directly proportional to that??
Any sort of Xplanation that can be given for the above is most welcome...
Kinds of Shues
Re: Kinds of Shues
As far as i know, the shues differ in lvl requirement to mount based on the number of basic properties.
if the shue has 1 basic property (either attack or def or Exp%) - you can mount it from lvl 1
shue with 2 basic property - lvl 30 to mount it
shue with 3 basic property - lvl 60 to mount
I do not think there is any other property either hidden or visible is available to those shues.
I am not sure if that even comes close to explaining... and i wasnt going to reply if i dint see the like quoted below
Zangetsu wrote:Any sort of Xplanation that can be given for the above is most welcome...
well if u referring to the properties that i mentioned, the lvl restriction doesnt depend on the Eles. only on basic propertiesZangetsu wrote:i myself had a shue with 4 ELE's which i used from lvl1
Basic Attack (Not ele)
Basic Defence (Not ele)
Basic Exp increase
You can even have a 6 ele 1 basic shue which you can mount at lvl 1
