Question 1: Can an olgoc or leedeeg contain only 1 item ? Or does each of the splitted creep possibly have a chance of dropping an item?
Question 2:If answer to Question 1 is yes ie each of the five olgocs have chances of dropping something ? then what happens when the olgoc does not split properly ?
Question 3: This happens during freezing if there is no space surroundin the warrior the creep splits into only 1 or 2 more creeps
So what happens to the drop in the rest of the olgocs ?
Looking forward to arthas answering this
If this is a noob doubt pls forgive me [:D]
A doubt on olgocs & leedeegs
Hi Dude!
As far as my understanding goes each of the olgoc or Lledeeg is a seaparate entity. The software randomly decides at the time of kill whether an item or which item will be dropped.
So, if an olgoc spwans into only 2 or three only those 2 or 3 olgocs will give drops (if any). Theoretically you have missed the chance of drop from the other 2-3 olgocs which did not spawn because of space constraint.
Gurus of A3, please confirm this.
Cheers!
Cheers!
Re: A doubt on olgocs & leedeegs
Hemu has answered them all , here is the same post as above, with
should i say... different words...
adriel_frederick wrote:Question 1: Can an olgoc or leedeeg contain only 1 item ? Or does each of the splitted creep possibly have a chance of dropping an item?
Each ogloc/leed is a seperate creep or should i say monster...
Well ur chance of getting drop decreases, more creep u hit there is
more chance for some drop
Same, drop chance decreases for u (Chance of drop from 1 ogloc is still
the same). Some ppl intentionaly make sure less creeps spawn.. eg when
player is at lower lvl.... hmmm old days ive done it with oglocs near the
rocks at carode...
Try using Earth pit before freeze. u will get more creeps than when u hit freeze directlyadriel_frederick wrote: This happens during freezing if there is no space surroundin the warrior the creep splits into only 1 or 2 more creeps
